Yes, have a freebie. There is no slow motor speed, only one speed available. The wheel is a model, and could have an electric braking mechanism, but proably not at this level. It simply coasts to a stop. Hopefully the switch magnets are strong enough to stop it at a seat as it slows to a stop.
It really will not matter (only a model) if it stops at any particular seat, as long as it stops at 1 of the 4 seats. To help with this, a small spring indexing drag brake could be made from a rectangle of springy sheet metal - maybe use a piece of old steel banding strap, which is very stiff and springy but also hard to cut and drill. You could use a grinder to cut it, and a titanium bit to drill holes in one end. Position the brake to drag against the wheel spokes to make sure the wheel stopped with a seat in the Unload/Load position. Also if you have an old steel tape measure that is broken, you could use a piece of the spring from that to make the brake. I have 2 or 3 broken tapes in my tool box from years past!
See Rung 007 in my last Outline R1 for one way to try to stop the seat at a magnet. It might work, depending on if the motor is geared down to turn the wheel slowly. If not, another timer will be needed to allow the wheel to coast down to a very slow speed before looking for the next reed switch closure.
The key is not to try to stop the switch from activating, but to prevent it from stopping the motor EXCEPT at the right times. Use your timers to run forward or backward until a certain time (perhaps 30 seconds) is reached THEN start looking for the next seat magnet (hopefully it will be strong enough to stick at that point or at the next seat).The problem is how can I stop the reed switch activating whenever the magnet comes close to the switch, when it is going forward or backward, without wanting to load/unload. (Loading and unloading is what the reed switch is for).
