Need help with subtracting a fixed value from a digital value
tempname24756
Nov 2015
sweden
Basically I have a digital value I need to scale down using this equation:
'end_value = (D1-1000)/100' but I'm having trouble writing it down to my program.
I've created a local label which is of a VAR_CONSTANT type and the data type is word[signed], the value of this variable is 1000.
At the moment it looks like this
 -|/|--------[-P D1 var_1000 new_var]
If I've understood this correctly the new value should be stored in 'new_var' but it remains 0. I'm out of ideas and I've tried to read Mitsubishi's "Q-series basic course(for GX developer)" manual.
The contacts and their names does not matter at the moment because all I want to do is (D1-1000)/100. I can add the code to the real program at a later stage when I have solved my issue.
Using GX works2
not familiar with this plc,just read the book,
my guess
LD X0
/P D0 K1000 D2
-P D2 K100 D4
OR
LD X0
/ D0 K1000 D2
- D2 K100 D4
Hi
Looks like MITSUBSHI Plc to me
I would either use the mov instruction or use the monitor window to force the valve in
Donnchadh
59
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
351
177
Good day all! Can someone help me with the procedure to update Beijers E700 firmware? The Panel I am working on is firmware 2.04v and I would...
86
