Need help with Testing an Application using FT View Studio V6.10
kandymann
Jan 2011
Virginia
168
Hello guys​
Software:
FT View Studio
FT View ME Station
Mark and rdcast have helped me in a big way with setting up communications using RSLinx E. I figured out my previous setback with their help! Thanks guys
I am new to HMI programming so once I got my communications configured correctly, I began testing applications and playing so to speak. I am working hard to learn this type of programming.
I am now working on a real life project and I am testing it. I am getting an error message when I test the application...
"Failed to load Tag Runtime Server"
I have been testing the same application over and over using FT View ME Station and now this pop up appears and I am unable to load the ME Station on my PC. It worked over and over again but after a few modifications to some displays, the ME Station will not load.
I assumed I needed to check out Communications Setup and I looked at the Runtime (Target) and made sure my Shortcuts: proccessor and tags were applied to both Desgin and Runtime.
I really dont know where to go from here.
Any suggestions?
Kandy
Start with a hard reboot of the computer.
Other Forum members will be along shortly to provide detailed opinions on the reliability of the FactoryTalk engine. :)
Ha
Well Mr. Roach
I rebooted my PC and when I opened FT View Studio I noticed a message at the bottom of the screen saying that my software was not vaildated and I was operating under a grace period. I went to my FT View Activation Manager and resubmitted my serial number, etc.
and walhaaa
It works now.
I have no idea why I had to reactivate my software like that. Weird. But hey, now I can get back to playing.
Thanks Ken
Is this on a laptop? If so I had an issue with this and it was because my activation was tied to the MAC address of the network card and not the hard drive serial number. I think it had to do with the network card in power saver mode while it was unplugged. If I turned it on unplugged it would go into a grace period.
46
347
173
Good day all! Can someone help me with the procedure to update Beijers E700 firmware? The Panel I am working on is firmware 2.04v and I would...
76
