Need help with timers in STEP7
Pandiani
Apr 2005
Tz
718
Hello guys,
I have one small problem
Idea is:
1. After time 10 s set "Step1"
2. After 8 s, set "Step2" and reset "Step1"
3. After 5 s, set "Output and reset "Step2".
I'm using PLCSIM. I know that when timer 2 is elapsed, step 2 is set, and at the same time Step1 is reset. Since Step1 is input to second timer, it's output is reset as soon step1 goes to 0. Because of that, timer 3 is not even starting.
One solution is to use temp variable and set/reset instruction.
This is shown in the second .pdf.
I wonder if there are more elegant solution to this?
Can you provide a timing diagram for what you want to accomplish? Do you want #Output to stay on after T3 if the input stays on or do you just want it to pulse? Can #Step1 stay on after T2 completes or must it reset?
Keith
Don't know if it is more elegant
Q0.1=Step1
Q0.2=Step2
If you want only a puls put Q0.0 at the reset of T1
Thank you guys.
Lauu, you surely know how to write clean and simple code, hehe....
116
74
393
200
Good day all! Can someone help me with the procedure to update Beijers E700 firmware? The Panel I am working on is firmware 2.04v and I would...
95
