Need Help with Totalizer Program downloading
onos_tech
Oct 2008
warri
At my work place, I programmed a totalizer for one of the plants with OB35 which worked fine. I later took the same to another plant, it did not work. Can any one help me with a solution on what the problem is?
That's like "I once ate a meal I enjoyed. I ate another meal that I didn't enjoy. Can anyone tell me what the problem was?" We really do need a little more information.
maybe a loose nut behind the keyboard
If the altitudes of the two plants are different, you may have to recalibrate the "Atmospheric Equalization" data registers. (see instruction manual)
I'm not an expert but with the information given by you I hope you try to download entire project into the plc and see...
are you sure that both plc's have same hardware?
Hello Onos_tech;
OB35 is a cyclic Organisation Block used in Siemens PLCs of the S7-300 and S7-400 PLCs. As such it will work as configured in the Config editor (CPU properties) as soon as it is downloaded to the active CPU.
Whatever you have programmed inside the OB35 is therefore more suspect. As you are doing a totaliser function I presume you are reading from an analog input (already scaled) and integrating it (summing it over the call interval of OB35). So, in the new CPU, the one where your function is not operating properly:
-are you accessing the correct analog input value (is your flowmeter connected to the same analog input address as in the first CPU)?
-are you scaling it properly?
-where are your running sum and result registers mapped?
Let's start with these points, if you can assure us all is OK there we will look at other options.
It would make things esaier if you were more forthcoming with details of your programs, maybe you could include a screenshot of the actual totaliser function and a VAT giving us the results of the operation on both CPUs, for example.
Hope this helps,
Daniel Chartier
Hey everyone, I need to make a 24 hour totalizer for the total outfall of treated water to the ocean. There is a Flow meter measuring cubes per...
5,964
Hello all, I've got to make a totalizer for our digester acid fill using rslogix 5. I have a flow transmitter scaled for 0-16000 LPM using a CPT...
5,205
52
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
347
173
