Need program for alarm monitor circuit
glacr947
Feb 2013
Alpena Michigan
Useing the LogixPro Simulator, can anyone tell me how to write a ladder logic program for an alarm monitor circuit. In the circuit i must have a start and stop pushbuttons. Pump 1 and pump 2 along with the alarm light are my outputs. I also have a high level sensor and a selector switch for additional inputs. There is also a pair of TON timers and 1 CTU counter. If someone could advise rung by rung how to implement this i would very much appreciate it.
First define your system.
What is the alarm/fault condition you wish to detect? How would you detect it?
ALWAYS define your system first before you start writing code. When posting someplace like here, we don't know what your system is - it very well could be (don't know why, but it is possible...) that a motor being stopped is the expected condition and you wish to alarm when that motor is running.
What is the rest of your homework assignment?
169
Hi all, I’m new to programming and want to write a simple routine. Push start button, turns on sensor. 2 second delay before anymore logic read...
330
I will be designing an automated hydrostatic system. The system on paper works like this, a plc like the click will get information from an hmi...
227
43,094
Hi everyone, I'm looking for a sample program that has some UDTs defined in it for the MicroLogix platform. To create them, you need to have the...
2,217
Hello. I am working on a PLC program that needs to check input 1 after timer two is complete to see if a valve can close or not. Below is the flow...
2,833
