kamenges
If you really need to define your profile in terms of time like you have shown in the figure you posted, I would use Allen's method. I have done something similar in cases where I needed a true time-based ramp (the ramp takes the same amount of time regardless of the size of the change).
If all you are really concerned about is the time of the changes you can use theb Motion Axis Jog command (MAJ). You can use the timer structure that Allen shows to determine when to change speeds. Then just move a new desired jog speed into the instruction whenever you need to change speed.
You can do time based accels with the MAJ instruction also but you would need to divide your change by the amount of time you want it to take and use that as the accel rate.
The only thing the MAJ instruction brings you that Allen's method doesn't is S-curve accelerations.
Keith
Keith
