need to know the bit and word adress being used in tp270
harrydeharry
May 2008
Delhi
237
Dear all,
We are using a TP270 6" in our machine we dont have the original back up of the touch panel having two problems.
1) m trying to upload the backup with prosave and its getting disconnected every time in the middle and asking to check communication cable etc. I am using direct model cable bot side 9 pic d connector RS232. what cud b the problem.
2) is there any mathod to know that the which bit or data work being address through touch panel. as we dont have the original back up the touch panle.
thank in advance for your help.
Do you have the source code for the PLC (not the HMI) ?
If so, you can analyse the screen contents and find the relevant addresses in the PLC.
When you have found a candidate for an address you can monitor it online with a VAT table to see if it behaves as the value on the TP270.
In that way you can reverse-engineer the TP270 program.
A lot of work, but not impossible.
Question- Say I have 8 digital INPUTS to my PLC, any of which may be asserted HIGH for a few seconds, all these inputs "OR'd", currently, to...
3,556
Hey everyone, I'm currently in my last year of high school and I have to automate a scorebord for a foosball table using 4 optical sensors (sender...
38
6,346
I'm trying to display a 32 bit word from my PLC (ProWorx32), which I have used a double precision add block to achieve. The problem is, even...
2,466
This one is stumping me, it might not even be possible. I have machines running PLC 5's and machines running ControlLogix processors. When a...
5,545
I am using iFix 4.5 with drivers (ABR and IGS) configured to communicate with a PLC-5, a SLC5/05, and a ControlLogix 5500 processor, all over...
2,907
