need to read pulse in micro second
harrydeharry
May 2008
Delhi
237
Dear All,
We have to read the time gap of two rising pulse which is in micro second how can we do it in plc.(any plc)
thanks in advance.
You don't.
PLC's as a general rule don't have any input devices that can respond in microseconds.
I suppose maybe, you can find some type of extremely high speed counter to do this, but it's still unlikely.
You will be looking at extremely fast motion controllers, or more likely, dedicated hardware for this. You might be able to do it with an Arduino, or similar programmable system-on-a-chip.
I am working on a project right now where I have to compare two pulses that arrive just a few microseconds from one another. About 50 microseconds is the difference between an overload signal and an underload signal on a tiny solenoid driver circuit.
I'm using interrupts on an Arduino-based microcontroller (a Pololu A-Star 32U4) and communicating with my main system over Modbus RTU protocol. Everything else on the machine is automated by ControlLogix, but this specific super-fast function needed a dedicated microcontroller.
If you're working with Allen Bradley, I've used 1756-IB16IF cards for microsecond measurements before. However, they are better suited to applications with pulses of 10 microseconds or longer.
From the manual: "The 1756-IB16IF fast input module can be used to detect or latch short duration pulses. The module can detect incoming pulses with a duration as short as 10 μs if the frequency is under 4 kHz (period of 250 μs)."
automation direct
depending on how many micro sec you are looking at automation direct has a CTRIO high speed counter card that has the function you are looking for setup in it.
Yes arduino could do this, and also control more complex things.
On the other maybe a simple 556 can help you out.
You can have a converter from Pulses to Volts.
If you have analog inputs use them with this 555, if you dont have analog inputs make a PWM signal long enough to cope with the slow speed of the PLC.
Harry
I'm doing it with the Siemens ET200SP TM Timer module
You don't need a motion controller
PM me if you need details
I have a client asking for an inductive automation IGNITION SCADA system for a new lab in which they will test various engines that use a variety...
2,445
Need good example/sample of aoi RSLogix5000 code to read&write through RS232 port on Need good example/sample of aoi RSLogix5000 code to...
1,842
welcome sir i need to open this attach file to see ladder program for siemens s7-200 because i dont have software program [email protected] thanks
1,422
Hi all: I have a customer with two Toshiba EX28B PLC's. They had identical programs. One of them lost its program. I purchased a used EX2040PRGD...
1,904
OK, having a brain **** here, anyone remember if it's possible to read a floating point value from a 5/04 from a controllogix? Trying to do this...
3,529
