TConnolly
Well, I came along in the transistor era, but early enough to be in the computer punch card era. My college programming courses used punch cards. If you were lucky you could get on one of the electric card punches in the lab where you could key in the intstructions and data (in hex) on a keypad (Red 7 segment LED display) and push a button to punch the card. But there were only two of those, so most of the time I ened up on a manual card punch, you set the thumb levers, inserted a card, and pulled the punch lever. I learned the hard way that its a good idea to number your cards to keep them in order.
In my third year we got a lab with desktops. Altairs and Apple IIs. Big 8" floppy disk drives held 80K - the disk were almost as big as a phonograph record so the data on them was really fragile. I learned the hard way to purchase an extra disk and save everything twice on each disk.
The first controllers I worked with were DEC-PDP 8As - ferrite core memory - no micro-processor - it had a CPU bard (actually a four layer board assembly) loaded with gate chips instead of a microprocessor. We loaded the programs with punched paper tape and an optical reader, but the boot instructions had to be keyed in by hand (in hex) before you could use the optical reader. Then came PLCs where we could load the program by hand but then save it on a cassette tape with a tape recorder.
