new programme
downie
May 2002
rhondda
Can anyone help, I'm in the middle of writing a programme for a machine. At the moument I'm in a bit of difficulty, once the machine is fully closed i require it to stay closed for a set period of time then re-open for a set time (bump)then close again. Depending on the tool fitted will depend on the number of bumps required. So i think i require a counter in the circuit. Once the counter has been reached it will then stay closed for a given time(cure time). When this timer has elasped the machine will then open. There are two valves on the machine A being up, which is normally closed (no air flow). B being down, which is normally open (air flow). A and B not energized will maintain the ram down. A and B energized will allow the ram to go up.
Don't think we have enough information yet.
What type of PLC are you using?
How does solenoid A (UP) and solenoid B (DOWN) relate to open & close? Is UP = OPEN?
How many types of tools can be fitted? Do they all require different number of bumps? What does a bump refer to?
What happens on a power failure, does down solenoid operate (normally open, air flow)? Could this be dangerous if this happens?
What have you got so far?
Hello friends, I preferred to make a new post because the subject is not the same and I will see in time if my situation is good to put the old...
2,563
A client of mine bought a second hand pavers making machine and did not run it for 5 years.Unfortunately the battery was drained of the Omron...
1,663
1394 Assistance Needed I have qty 8 1394 units in various states of repair that I need to repair and test. 1394C-SJT05-T 1394C-SJT05-T-RL...
2,103
Can someone tell me how to copy programme from one PLC to another with all the data entered in it. e.g. the register values counter limits etc...
1,270
Hi everyone! My name is Vidy, I am having a problem whereby I was wondering on how would I go about trying to program using ladder logic to get...
2,080
