New servo product... Well, new to me
geniusintraining
Jun 2005
SC
8,280
Greetings all,
Last week I was up in Richmond VA for training on a servo system, I just want to put on my 2 cents if anyone is looking for a new system, I can recommend this one.
http://www.amkdrives.com/servo_motors_drives.htm
The system I have is older but still very good and solid, I have two, one is a 9 axis the other is 11 axis, years ago they bought the Siemens S5 technology (this is what I have) it has a S5 PLC embedded in one of the option cards, so its just like programming a S5 when you are writing the program.
The new technology uses CoDeSys as the embedded PLC, this brings me to the other thing that I would like to discuss, that software is un....real, you can do anything.
I don’t think they are cheap, but I can testify that they have very good service and a very good product, they also have a small servo that has the drive embedded inside it...that was cool it was a stand a lone system that could be chained to others.
Just wanted to share...
Re: CoDeSys
Yes indeed CoDeSys is a very impressive programming enviroment. Many manufacturers [primarily European] have partnered with 3S-Software to incorporate CoDeSys IEC 61131-3 into their products.
This presents are more standardized cross platform approach to programming and development.
Recently done a project using the Bosch-Rexroth MLC-40 [Motion Logic Controller]. This used the CoDeSys software. Takes a bit of getting used to, but once you get the hang of it one realizes just how powerful a system it can be.
http://www.3s-software.com/index.shtml?sp4
I'm looking for more process oriented advice, but for those who care I'm using an AB ControlLogix L3 processor and Kinetix 6500 servos. My...
26
9,126
Hi, I'm working on Mitsubishi MR-J5-70A amplifier, and need some advice on selecting fuse size. Main power is 1ph 240VAC, and in the manual, it...
80
Good morning, We've had an issue with a couple of servo valves and was wondering if anyone had seen anything similar. After a drop in pressure...
113
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
106
Hi all, I am having a machine with old 802d sl siemens controller. I am trying to tune servo by Siemens starter software. Anyone experienced...
77
