New to CC-link
DairyBoy
Jun 2007
UK
393
Hello all.
I have 6 inverters on a new project, connected to a Q00J plc. I have based the addressing on what I have interpreted from the cc-link inverter module manual. The plc module settings for the stations are all the same:
Ver.2 Remote Device Station, Expanded setting: quadruple, Excl station count: 1, Remote station points: 64.
For the first inverter, the inputs start at X100 and finish at X11F (32 bits) and the outputs are from Y100 to Y11F.
For the analogue values, the address is W0 through to W0F (16 words) for input to the plc and W100 to W10F for output values to the inverter.
For station 2, the addresses start at: X120, Y120, W10, W110. (the next consecutive addresses), and so on to station 6. This is the bit that I could really do with confirmation on.
I will not be able to test any of this until I arrive on the customer’s site at the weekend, so it would be very useful to know if I’ve at least got this bit right...
Any thoughts would be welcomed.
Thanks.
I'm struggling to get an FR-E800SCE to work on CC-Link IE TSN. I'm sure the issue is with the drive, when I plug in the network cable I get no...
105
Hi everybody, I would like to know if anybody here has already programmed with a LR-TB keyence on Io Link on a Rockwell PLC? And perhaps have...
82
Hi everybody, Is anybody here still have programmed a Keyence sensor LR-TB2000CL and used it as io link material in studio 5000. I would like to...
94
Hey there friends, recently discovered the world of industrial automation and learned what this fancy PLC can do so i am a super novice. Started...
346
Hi, I'm having an issue with a mircologix not transmitting out. The current setup is a mircologix 1400 connected to a Guardian 100 Radio...
116
