New to Siemens
Iangwf
Sep 2010
Castlemaine
Hi all
I've been sent a a Siemens MMC memory card from Germany for a S7-315-2DP CPU complete with code as backup for one of machines on site.
Is it possible to back up the MMC card with a field PG laptop (V11) so the files can be saved on a server.
I'd like to make a backup of the MMC memory card and place the file/files in our site backup register.
Can someone please help me with a step by step procedure on how to backup the MCC card using a Siemens Feild PG laptop.
I'm pretty sure you can just stick it in a card reader and copy the contents.
There are utilities you can use to make a disk image of the card too like HDDRawcopy
The real challenge is actually getting hold of a MMC card.
Hi Geoff
Thanks for the reply.
I was a bit lucky that I was able to get a card complete with code from the OEM in Germany.
I wasn't sure if there was any hidden files in the root directory of the card that could not be copied by windows on the Field PG.
I'll give it a go tomorrow with our Field PG MMC carder & let you know how I get on.
Cheers
If you insert a Siemens MMC card in a regular flash card reader, there is the risk that Windows will misinterpret the existing formatting, thinking it is non-formatted and suggest to format the card.
Based on which Field PG you have it may have a special MMC prommer, but it may only be a regular flash card reader.
Unless you are sure, dont insert the MMC card in any flash card reader.
What is the exact type no of the Field PG ?
Do you have TIA V11 ? Do you have STEP7 Classic V5 on the field PG ?
Hi JasperMP
The field PG has the following on the bottom it:
M3
6ES7715-1BB23-0AE2
F-NR. SVPC4855497
Contains FCC TX ID
PD9622ANH and IC: 1000M-622ANH
Contains D40 AM5:
US: AGSMD01BDELPHI and IC: 4005B-DELPHI
It has the following Siemens software installed: Simatic Manager (V5.5+SP1) and TIA (V11).
I've been told that the small card slot on the right hand side of the laptop is for MMC cards and the left hand slot is for regular SD cards.
When the MMC card is inserted into the MMC slot on the PG, Simatic manger can open the MMC card, not sure if the contents can be saved into a regular file from here or not. (See attached screen shot)
When the MMC card is inserted into the PG SD slot windows cannot see the card.
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
97
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
293
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
105
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
159
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
197
