Newly acquired 'old' hardware
Jan 2013
Michigan
41
Hey guys... still learning what all the different AB models do. I have a machine here that has some 1794-based FlexIO modules (with the AENT) and a PanelView Plus 700 attached to it, but no 'main' control panel at all. There was a CAT5 cable going to each, but cut off with a sawsall apparently. :p
So, the question is: What sort of PLC and Ethernet stuff would have *likely* been at the other end of the cables? Control Logix? Or... ? :confused: Thanx!
... with 1756-ENBT/1756-EN2T
or FlexLogix with 1788-ENBT
or 1768 CompactLogix with 1768-ENBT
or 1769-L32E CompactLogix
or 1969-L35E CompactLogix
or any CompactLogix 5730
I have one old Ansaldo VFD from 37kW and it have only sign OFF on the display after put it on the 3x400VAC. Is there any idea, how to solve this...
35
82
118
This is admittedly a pretty obscure problem, but maybe someone else has run into it, or at least something similar. For reasons I won't get into...
154
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
262
