No plc thing..:(
theripley
Jul 2008
laguna
545
As the title suggests, this is a "noplcthing" question. This thread regards to intersecting two identical laser beam. As I was looking thru the net, researching for results of two beams (with same frequency) intersect & its outcome, I decided to post it instead.
I have two identical laser beam sensor (both through-beam) that needs to be installed in a cross-manner. My definition for cross-manner is that both beam intersects @ a single point. Will this create interference? If so, what kind of interference?
Isn't that a time machine?
http://www.google.com/url?sa=t&sour...sg=AFQjCNFt2Mkvdp2vS9hPi7EeSeHWfPyjAw&cad=rja
Im not trying to make a time machine, that's definite:) well, I was just concerned that if both identical laser beam sensor collides at a certain point, one or both beam may become weak that it can no longer detect presence or absence of object.
I was trying to test it using two colliding beams of photoelectric, the result was one beam becomes weaker when collided with the other beam. I'm not sure with the laser, i think the latter has stronger beam than the former.
I have a new job programming PLCs and HMIs after being away from them for ~7 years. I am trying to establish a test setup with an old AB...
3,948
Good Evening , I need to convert a PLC 2/17 ( RS Logix 5 ) over to a CompactLogix 1769-L33ER . I took notice in the RS Logix 5 program that...
2,101
We had an enclosure unfortunately fill up entirely with water. We had a different components in there, a Dynamix 1444 Module and terminal base...
4,138
I can find plc in RSlinx lite but when I open Logix RSWho there is nothing there. The driver I added in RSlinx doesnt even show up in Logix RSWho...
16
5,915
There are plenty of examples on the internet of how to make an LED fade on and off in a sort of pulsating or breathing pattern, but these all use...
17
5,893
