Non-Retentive Timer OFF-Delay Question
coldplay2010
Feb 2019
Richgrove
Hello guys, I am currently looking through some examples of how timers work, but this ladder logic diagram gets me really confused.
Once I:1/0 is open and the timer starts timing, the green light should be energized. Once it ends timing, how is it that the red light turns on instead of turn off? I have the simulator, but I still do not understand.
TON works with a delay to activate the output.
TOF works with a delay to desactivate the output. If you lose the input condition, the timer is activated and start counting, and the output of the timer is only desactivated after that the time has reached the preset time.
In resume:
Input True: Output true
Input false: Timer start decrementing, output true
Time is elapsed : Output false
Input back to true: Output true
I have a question about the TOFR instruction, a non-retentive timer that accumulates when the input bit goes low. For me this is in Rockwell's...
3,714
Been a long time since I've posted, but here we go. Started a new role in august and progressively learning about Codesys programming in...
1,156
GE 90-30 using ME 6.0 - Newbie question... Let's say on rung 10 I set a coil (S) with a one-shot. Input to coil drops out, but coil stays...
30
11,094
Hi All I have tried to use the following code to reset a tmr. if Cycle.St & not(CycleStart_Rst) then Tmr_Main.Reset [:=] 1; CycleStart_Rst...
3,683
I am using some MCR pairs in RSLogix 500 as if they were subroutines. I could, for example, have used JMP & LBL instruction pairs instead. When...
6,156
