Not able to understand Control and Status words...Simovert Masterdrive.
drspanda
Oct 2005
Damanjodi
155
Dear Experts,
I am using Simovert Masterdrive 6ES77032-1EG60-Z connected to S7-400 through CBP2 card 6ES7090-0XX84-0FF5. The problem is I am not able to understand the S7 program and after trying for several times I request your help.
In Hardware configuration I have found that Input address is 712..715 and output address is 536..539 for this drive...and PPO3 is being used...As far as I know PPO3 gives me 2 Words from PZD area and 2 Words into PZD area...
In S7 program PIB712 is moved into MB251, PIB713 is moved into MB250 and PIW714 is moved into MW3056 "process value".
Also, MB252 is moved into PQB537, MB253 is moved into PQB536 and MW1540 "setpoint" is moved into PQW538.
I have referred to the manual 6SE7087-6JK60 "control word and status word" - Chapter but I could not understand fully.
I would like to request you to guide me the significance of each bits so that I can understand the code.
Dear L D[AR2,P#0.0],
Just now finished downloading the manual from siemens web site "SIMOVERT MASTERDRIVES Vector Control Compendium VC34 (Operating Instructions)".
I think it will more than 2 to 3 days to go thru the manual...As I dont have a habit of reading in PC...
I shall come back if required for any help.
Thank You.
Hello, Can any one help me about hot use BSL and BSR in Slc 500. After configuring how to use it to distinguish different products in an assembly...
4,394
I am calling FC4 through which I am just monitoring the input, which if persists for more then 10seconds continuously, will make the output high...
17
5,127
Dear S7 Experts, After several attempts I have come to conclusion that I should seek your help...The below is the stl source code. FC311 calls...
8,597
52
I am considering using a "magnetic cable tie mount" like this one: https://www.grainger.com/product/MAG-MATE-Magnet-with-Zip-Tie-Holder-49M018 It...
93
