not supported by the installed version of Factory talk alarms and events
Sep 2014
nc
60
Good morning,
I have an error that has came up in my factory talkview program, that states the follow:
“the firmware of the controller PLC1 is not supported by the installed version of Factory talk alarms and events. The firmware revision must be 16.20 or higher, excluding 21-23.”
This is the second project that I have setup with factory talkview se 8.2 and studio 5000 v.21.
Both projects are identical minus a few tag names.
What needs to be done to fix this error.
Looks like Rockwell needs to have a patch for software error.
How do I fix this problem?
Hello all, and thank you in advance for any assistance you may be able to provide! This is my first post, so if I need to reformat or change...
490
Hey all, So in Studio 5000 you can go to...communications -> select communication software...and then choose between RSLinx or FTLinx. However...
240
Does anyone ever get this error? I am using factory talk echo as the emulator, and I've tried to online with it, and I keep getting the error...
1,920
Hello: Some time ago I wrote some basic code for a GuardLogix, in which I needed to add and subtract tags of LINT data type. When tried to use the...
3,758
I'm working on getting a handful of devices hooked up to an EWEB card on an Allen-Bradley 1756 PLC using the Ethernet/IP socket interface, and...
2,054
