Off topic question
Soggy Canuck
Jan 2008
Vancouver
229
I bought a AB 836e pressure transducer 4-20mA o/p. The included wiring diagram shows sig+ only. Am I supposed to take the sig- input at the plc to the 0v of the sensor power supply?
Page nine kind of illistrates where I'm getting hung up. The dotted line coming off the bottom of the input device .....on my plc, where would I tie it to?
After reading the manual (something you can also do) it appears that you could have one of three different units.
1) With display - two PNP outputs. The unit functions as a dual limit device using limits set via the display portion of the unit. Can indicate OK/HI, HI/HIHI, or whatever you set the setpoints to. There is NO analog output at all. That's the first diagram (leftmost top) on page 9.
2) With display - one PNP output and one analog output. The unit functions as a single limit device using limit set via the display portion of the unit. Can indicate OK, HI, or whatever you set the setpoint to. The negative side of the analog is connected to your power supply negative. That's the second diagram (rightmost top) on page 9.
3) Without display - one analog output - wired as shown on bottom of page 9.
Does this clear things up for you or do you need further direction?
I'm looking for an annoyingly bright 3 level light stack. Any voltage ac/dc is workable. Most of the ones I've seen are not very bright and I'm...
1,584
We are mounting a diesel generator to a diesel box truck. I am trying to figure out whether we should use the truck's battery or add a separate...
3,473
What type of employment is out there with an Associates Degree in Mechatronics with 16 years electrical experience and a Electrical Contractors...
1,693
Sorry about this off topic question but i can't finish my PLC program changes because our IT guy couldn't remember how to get to the editing...
2,061
Hi, I need to compress 3000 ft^3 of a syngas(synthetic gas) made up mostly of hydrogen, carbon dioxide and a little methane. I cannot seem to...
2,526
