OFS -modicon M340
AmerK
Jul 2014
Sarajevo
Hi guys,
I'm trying to connect M340 via OFS, and i cant read tags.
So far i created alias, added symbol table file ( .XVM format) , and i'm using usb connection.
When i run OFS client i can add tags (they have some exlamation mark as icon), then when I try to read them nothing happens, when i try to change their value some error occured (screenshot1)
Also, i noticed in OPC factory server/network info that device access is DISABLED and each time when i tried to change value of tag it says: Warning, item not consistent. (screenshot2)
Any suggestions ?
Thank you.
Hello, Just wondering if it is possible to make internal CitectSCADA project tags available to an OPC server. (Schneider OFS). There are...
929
I've got a client who wants to pilot a Schneider's M580 controllers in Unity Pro and use their OFS OPC server to read tags straight out of the...
1,351
Hi to all I need to write a quick application using Microsoft Visual Studio (c#) and Schneider OFS server to reading some variables not allocated...
1,891
Hi there, When an alias is configured in OFS using a .xvm file generated from unity (quantum plc), does OFS uses the topological addresses? We...
2,296
Hello folks, i bring you a new problem to be solved.. Situation: we have 2 PLC M340, 2 PC's running 1 vijeo citect license + 1 ofs opc each. for...
1,881
