sasquatch
What is the best way or products to use in order to monitor a variable resistance and control a motor speed?
sasquatch said:I probably need to clarify some more. I am trying to use a resistance input from a product in order to control a motor speed in order to keep the resistance on the product rock steady. Hopefully, that will explain it better.
panic mode said:RTD transducer is the easy way to convert resistance (with range you mention) to an analog signal suitable for PLC or VFD inputs for example...
most devices will do 0-6000 Ohm, some will do higher such as 8 or even 12k (i think...).
why are y'all responding?
How do you respond before understanding the applicatuion?
sasquatch said:I dont understand what is so hard to understand about the question. ....
Also, you have to realize that I cant give away company secrets no matter how much you try to pry them out of me. So, if you cant understand that, then the problem is not with me.
Does this mean that you want to control the speed (VFD?) with a Potentiometer (or resistance value) now? Does this mean futher down the road you want to change the speed with a plc using a potentiometer (or resistance value) as a input to the plc? I think what is confusing the forum members is normally the output from the plc is either voltage or current and not ohms. Your posts imply that you want an ohm value from the plc. I have never seen an ohm value output from a plc (doesn't mean that one doesn't exist).sasquatch said:I am going to get a plc to control a motor speed based on a resistance input. Both the input and the output are analog.
If you can't answer this question because of company secrets then I don't think anyone here can help youpanic mode said:it sounds like you have VFD but you still
didn't mention it clearly
This appears to state that you can get a module. Then two sentences later you ask if you can get one. Most of us here are confused by your description.sasquatch said:I know that I can get an analog output module to control the motor. All that I need for now is an ohmmeter input. Can I find a module that will do this or should I have an ohmmeter specially made which will hook up to a plc?
