Ok Ethernet Gurus!
Mtn_Bkng_Dave
Feb 2004
South Carolina
130
Does anybody have experience with a Bruker Optics FT-NIR and transmitting quant results to a PLC via Ethernet/IP? I am going to interface this system to my fractionation process and need to be able to make control decisions based on the distillate composition analytical results.
Using a ControlLogix processor (L61) with Ethernet/IP.
Pipe in here Ken.......this is all you! :)
Dave
I don't see any technical information regarding interfacing to the FT-NIR on Bruker Optics' website. What makes you think their analyzer has EtherNet/IP protocol at all ?
I have a bad feeling that they've told you that the analyzer supports "Ethernet", not knowing anything about the protocols used in the industrial market.
Ethernet Support
Ken,
I just got some info in from the factory.....
I can send reports via DDE to another device. I wonder if RSLinx Pro will do the trick?
I'm currently using Wonderware ABTCP but its not really configurable for other topics other than what Wonderware is looking for.
I may send it into my Intouch node and do all the stripping and extracting there and then send the raw data down to the PLC.
They sell a nifty package to do it but it operates on Modbus so they say.
This should be a fun one.......
Dave
When sending an Ethernet message with a Control Logix processor using the MSG instruction should the enable rung be a one shot? I'm sending a...
2,858
194
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
101
So I have a sort of unique situation where I'm wanting to run a PF755 from the IO and over ethernet. Of course, this comes with it's own set of...
320
Hi all, My ethernet port on my laptop recently broke and I was hoping to just use a usb-c dongle in the mean time to go live on my PLC until I...
478
