Old B&R CP60 cpu don't works and shows error codes...
JoanM
Sep 2013
Barcelona
92
Hello all,
Does anyone here has an error codes list for that CPU? B&R CP60.
This is older than 1995.
The codes that appear in the status display are:
035 and then 034.
The CPU has an EP128 eeprom installed.
There are some outputs ON, but it looks like nothing else is working...
Thank you very much!
Thank you gclshortt for your post, but it has not helped at all...
Before coming here I contacted B&R and they had never seen a PLC like that before (now they are contacting Eggelsberg directly to try to get some help).
The problem is that the company that created the machine is not there anymore, the software is not available, neither the cables... so I'm trying to know if those two error (<-- that is a supposition given the only manual I've been able to find) codes mean that a card is failing or if the eeprom is dead...
If the eeprom is dead, then I'm afraid the only solution will be to put that old PLC to rest in peace and change it for a newer one...
Again, thank you for trying.
I have one old Ansaldo VFD from 37kW and it have only sign OFF on the display after put it on the 3x400VAC. Is there any idea, how to solve this...
40
Hi all, looking to model old RR relays in PLC. Does anyone have any SPECIFIC examples on how to model a relay such as a polar relay, slow pickup...
84
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
119
This is admittedly a pretty obscure problem, but maybe someone else has run into it, or at least something similar. For reasons I won't get into...
154
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
262
