Old "IPC 620-20 PLC"
I've got a hard (paper) copy of some manuals. But lot from it in German. If you intresting, I can scan any pages for you.
German is ok. I am special interested in the section about memory. Does the CPU work in Ram or Rom, and reference on start up if the main power has been gone for one week?
I have an old system without any dok. And the cpu is cold. If we cant get it working I will need to put an new cpu system and a lot off programming.
IPC 620-20 used with external memory module CMOS RAM (MM) 620-0025(2 kWord), 620-0026(4 kWord) or 620-0027(8 kWord). If D-size battery in CPU Power Module was dead and general power wasn't pluged you need make the new loading or programming PLC. IPC series was developed at Moeller for Honeywell. Small set of manuals I find in http://content.honeywell.com/ipc/faq/ but now this server isn't ask. :(
For Honeywell 620 manuals:
1) Register at the bottom of page:
http://www.pscsnapshot2.com/imc/scripts/silverware.exe/showplin@d:/dfs/elevclients/IMC/elevator.fxp
2) Once registered, you'll be directed to the welcome page for Honeywell literature.
click "other IM& C Products" tab (upper right)
3) click "Modular Control Solutions" button in left naviagation column
4) click the "620LCS" link
5) search the 6 pages of links to manuals for what it is you need.
6) Don't forget to take care of the reindeer.
Dan
I'm don't find the manual #620-8998 (620-20) or #620-8997
(620-30) at this page
I have one old Ansaldo VFD from 37kW and it have only sign OFF on the display after put it on the 3x400VAC. Is there any idea, how to solve this...
71
Hi all, looking to model old RR relays in PLC. Does anyone have any SPECIFIC examples on how to model a relay such as a polar relay, slow pickup...
95
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
134
This is admittedly a pretty obscure problem, but maybe someone else has run into it, or at least something similar. For reasons I won't get into...
164
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
271
