Omron 3G3MX2-AB004-V1 Inverter (VSD) Homing & Relative Move FB??
ric007ishere
Jul 2017
Melbourne
Hello all,
I have a Omron 3G3MX2-AB004-V1 Inverter (VSD) connected via EtherCAT that I need to reference (home) and also perform a relative move.
I am looking for a Function Block with the following Inputs/Outputs for my
Omron NX1P2-1140DT1 PLC for use in Sysmac Studio.
Inputs
- Takes the Encoder signal as a Position obtained via a Motion Control Axis (setup as an Encoder axis)
- Takes a Homing sensor input (Sensor triggers on each conveyor belt cleat)
- Take either a Reference or RelativeMove signal (to Home the inverter or MoveRelative respectively)
- Takes the distance to move for a RelativeMove
Outputs
- Forward
- Reverse
- Velocity
- Done
- Busy
- Error
Has anyone done this before from a PLC FB for this inverter who could help me please?
Many thanks!
Richard
Hello Guys, I have a Omron 3G3MX2 drive and I want to learn how its Modbus registers work by connecting to pc via Modbus poll software. does...
750
Hello Guys, I have a machine that have 8 Omron 3G3MV VFDs and I am looking to migrate to Omron 3G3MX2 drives. the existing network is half duplex...
579
Hello gentlemen, Another day another drive:banghead: I have an OMRON inverter 3G3MX2 which I put in to replace a damaged one both of which are...
2,732
Hello guys, I am searching for device driver to connect CX-Drive to a 3GMX2 drive. Tried google and tried OMRON at this link but it looks like...
3,871
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
50
