Omron and Smart Motor
valerianlin
Feb 2017
ontario
18
I am fairly new to PLC's and have been given quite the task by my group members. For our project we are using an omron cs1g, and trying to get the smart motor similar to the link below
http://www.animatics.com/products/animatics/nema-34-3400-series/sm34405d.html
from moog animatics to communicate with each other. The smart motor comes with the smart motor interface software which is sends the commands to the motor, similar to how omron has cx-programmer. The motor uses an rs232 port to connect to the computer, and we have a serial communications board for the omron with an rs232 port available. We noticed there was a built in sniffer in the smart motor interface program and when we sent commands, they came out as hex. Would it be possible to send hex directly from the PLC to the motor via the TXD instruction? I have not looked into too much because I am not sure if this is possible or not. The TXD instruction has a source word, a control word and bits to send which I am not too familiar with. For example 47 in hex would come out as G in as ASCII which starts the motor.
https://www.google.ca/url?sa=t&rct=...zU0kcIkobaVvMmrXh8cZtg&bvm=bv.148073327,d.amc
The manual linked here states on page 64 under "getting data rs232 port using data mode", in data mode the motor will simply respond to arriving commands it recognizes.
Would anyone here be familiar with smart motor and omron plc? I apologize if my post is all over the place there was a lot to explain.
Thank You
Our machine builder is assembling a new machine using Omron Smart Slice I/O. Apparently there is an instruction sheet which specifies wiring to...
2,510
Hello all, Could anyone help with some advise on generating comms alarms on a Omron Profinet network. I’ve got a CJ2M Omron PLC with several...
2,598
I have given a task to run omron smartstep servo with S7 300 is any body have experience on this and help me out Thanks in advance
2,026
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
180
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
72
