Omron Smart Slice I/O
kku
May 2013
Toronto
39
Our machine builder is assembling a new machine using Omron Smart Slice I/O. Apparently there is an instruction sheet which specifies wiring to the slices without using ferrules. Only stranded or solid wire is allowed in the U.S. (and I guess Canada as well). Why would Omron say this? This note is not in any of the regular manuals from what I can see.
Probably because the connecting points terminals are not rated for the physical "stress" induced when a ferrule end is being compressed/flattened.
I have seen it every now and then posted within "delicate" components' Installation/Wiring Instructions.
The weird part is in the manual they suggest wiring with ferrules. I don't know why North America is different. The attached screen shot is from the manual.
Hello all, Could anyone help with some advise on generating comms alarms on a Omron Profinet network. I’ve got a CJ2M Omron PLC with several...
2,598
Hi, I am fairly new to PLC's and have been given quite the task by my group members. For our project we are using an omron cs1g, and trying to...
2,253
I have given a task to run omron smartstep servo with S7 300 is any body have experience on this and help me out Thanks in advance
2,025
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
178
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
72
