omron apr instruction
irondesk40
Jan 2008
nc
630
have a program that I have inherited that the instruction.
APR
D3570
D3501
D358
The value in D3570 is equal to 800 hex (+2048)
Could someone explain this instruction in simple terms?
I am tring to help a tech here in Dominican Republic and this instruction is just not making any sense to me at the moment.
THANKS
APR is a multi function instrustion - depends what the programmer has used it for. I commonly use it for linear approximation of a non linear curve. Are there any comments that may indicate how it is being used? Do you have a manual describing the functions?
For example, for linear approximation one would set up a table refernced in the instruction to say that eg the number count for 5ma input is 300, 6 ma is 472 ets and then the function will linearise the output. Particularly useful for cylindrical tanks on their side with belled ends.
By the way, Omron are the only PLCs I have used that have that function - there may be others but I have noy used any.
Could someone explain the APR instruction in what might be considered easier to understand terms than what I have read in the manaul. Just having...
8,684
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
178
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
67
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
111
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
264
