Omron C20
Donnchadh
Jun 2002
Ireland
1,004
Hi all
I have a Omron C20 plc that has faulted.
I am not able to go online as I do not have
the program unit to connect to it.I have downloaded
the software from a web site.I am hoping that someone
might be able to sell me the program unit I need.
Thanks again
Donnchadh
You will require Syswin for this very old PLC. You will also require a 3G2C7-LK201-E interface unit and a special cable. You may be able to find the interface second hand on Ebay.
What's the nature of the fault? Is the power light on? Is the Run light on? If so you likey have a bad I/O point. In that case if there's spare I/O you might be able to move the program instructon to address a different I/O point.
I have a programmer & a host link etc.. However they are not for sale. If you get desperate feel free to PM me. We may be able to arrange something.
Have you tried contacting your local Omron rep/distributor?
From looking at the website, the closest is the UK. They may be able to loan you the item if need be, but if you are going to continue using this version, it may be worth while getting hold of an adaptor for yourself.
I cut my teeth on these...
Is it a C20K, or C20H? If it's a "K", then Bob's advice is correct. Another option is the 3G2A6-PRO15-E handheld. The "H" series is newer (but still old), and uses the C200H-PRO27 handheld.
www.plccenter.com sells everything you need, but be prepared to dig deep in your wallet... :eek:
-Eric
P.S. As soon as you suck the program out of it, plan to replace the PLC with something current... :nodi:
Omran C20
Hi All
Thanks for the replys.The power light is on with no run light.
We have got the software but are having trouble getting the right
comms module.I have now priced changing out the plc to a AB compact
logix.Thanks again for taking the time out to read my post.
Donnchadh K.
Donnchadh,
Do you have a maunual for the C20(K or H)?
Also consider the possability of sending the PLC out to somebody who can either print out the program, or mabey even fix the problem.
I have a Mnemonic code for the above PLC. I wish to convert it to ladder diagram but the code is a bit complex. I am looking for someone to assist...
17
5,694
Hi, I have taken over maintaining some HVAC units that are run by the Sysmac C20 PLC. To keep a stock of PLCs handy we have had to buy used PLCs...
2,310
Hello, I purchased a machine with an old Omron C20 PLC. The machine functions as we would like; however, I am concerned that I don't have the...
3,004
The PLC stopped working - likely a failure with in the power circuit (no power light). We have a code printout but one page is missing. How can we...
3,077
I am looking at a dead C20, and the owner wants to go AB, which is my preference too. I have not worked with Omron since trade school. I have...
2,935
