Omron C500
Guest
Guest
G
Hi All
I USE PLC OMRON-C500 BUT I HAVE NOT EXPIRINCE WITH SPECIAL
AUXILIARY RELAYS
EXMPAL
CH 25308 THIS RELAY TURNS ON WHEN THE BATTERY IN THE CPU IS
ABNORMWL.
I WANT USE THIS RELAY WITH OUTPUT INDICATOR LAMP
THX
This should be as simple as monitoring the bit and using it to drive an Output.
Special Battery
Relay Indicator
---| |------------------( Output-X )
If you want to get a little fancy, you could add a flasher.
Special Flash Battery
Relay Bit Indicator
---| |---------| |------( Output-X )
OMRON C500
HI terry
I KNOW WHAT U MEAN BUT MY PROBLEM IS I CAN NOT WRITE THIS RELAY NO. IN LADDER. FOR THAT I NEED SOME ONE SPECAL IN OMRON PGM.
THX
Hello,
According to my manual, the Low Battery flag is bit SR61.08.
However, I think that you do not need to enter 'SR'.
61.08 Alarm
Low
Battery
Hope this helps ;)
The low battery flag is 61.08. Just address it as that as an open contact and output it to either an internal or external output.
If you are using Syswin, it is listed in the system bits in the symbol editor.
  61.08          10.00
Hi, Can same one help me I am getting a error on my Omron PLC that stop my scada coms. The PLC is a C500 CPU CVM1 CPU11-V2. The error is...
1,655
G
Hi, On one of our Generator we have "OMRON SYSMAC C500 3G2C3 CPU11E". This system was commissioned in 1987 and was working trouble free. For last...
8,566
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
178
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
69
