Hello im new to plc programming with Omron Cx Programmer
I have made a program to trigger timers one after the other and repeat the process continually, but the problem im having is that I need each of the output coils to be on in sequence of the timers but I cannot find a way to achieve this .
Basically I want coil 1 on and coil 2,3,4 off while timer 1 is running then coil 2 on when timer 2 running coil 1, 3, 4 should be off and so on
I have achieved this using rs logix 5,500, and 5000 but being new to omron and their timers it’s hard or time consuming to find the equivalent of rslogix t1.DN and t1.tt , t1.en and so on.
What I know so far in omron I can trigger the timers to cascade using T000 T0001… and so on but they stay enabled
I have attached the program I made so far so take a look at that and get back to me. Thanks
Im using cx programmer 9.2 and the plc is Omron cj1m
