I have an Omron CJ1M that I would like to be able to read and write to from a C-More HMI over an existing ethernet network. I have a ton of IAPs and ENI adapters on the network that I've used to connect Allen Bradley SLC 503s and Micrologix 1100s to the network.
I have the Omron PLC connected to an IAP and can connect to it using CX Programmer over the network using RealPort. From what I can see, there are no Omron ethernet comm drivers to allow me to connect to the PLC like I do with the Allen Bradley PLCs (RSLinx has Ethernet drivers). Is this correct?
Is there a way to get the C-More communicating with the CJ1M using the C-More's ethernet port,or do I have to use another IAP and set up a serial bridge?
