OMRON CJ2+EtherCat Reference Wanted
PDBRider
Sep 2012
Michigan
I am using direct operation and have my EtherCat setup to handle 9 servos (Basic Positioning).
Does anyone have a reference with multiple servos using EtherCat? I am looking to see how to handle faults, the jog spd selection, jog enabled/direct operation enabled, and positions complete. There's few a bit of bits I do not understand 100%
A.13 Immediate Stop, is this the bit I should use to stop the servo while is searching for position based on input? Or is this more reserved for E-Stop conditions?
C+2.13 Positioning Operation Completed, This would be the reached position and the movement command has ended, correct?
C+3.7 Positioning Complete Waiting Flag, this would be the busy/in motion bit?
C+4.4 Absolute Movement Flag, same as 3.7 in relation to the Absolute cmd?
C+8 Present Command Position, is this the current position or current position the drive is being told to go to? I would like something to say where the drive is (ie. at 100mm) to confirm its in the correct location/position.
Good morning everyone I’m currently working on a omron device net and have a nord drive that fell off the network. I have limit knowledge in...
32
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
70
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
206
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
86
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
147
