Omron CJ2MCPU33 addressing array of dint
Tommycai
Aug 2011
KY
120
how do I address the bit inside of a dint array in Omron?
I made my global DINTArray[4] (starts at W11) how can I address the bit of W11.00
I tried Address[0.00] & Address[0].00 & Address[0].0 Does not seem to like any of these is there a way it will work??
What are you trying to do with the bits??
You can address them directly as a contact or coil by directly addressing them. (i.e. W11.00)
I am trying to make an array called Fault with the address of DINT array 4. Then I want to access the bit of that array instead of the entire DINT. Is this a possibility in Omron?
Not really because the bit numbers are limited to 0-15 so you can only access the low order word in a DINT. There is no way to get to the high order bits 16-31.
You could access them through an index register as individual bits, but index registers can be a bit tricky. You would have to point an IR at the base of the array and a DR at the bit number in the array. Look at section 5-7 of the W473 manual.
so I have a omron CJ2M-CPU33 with a serial Port card adapter plugged into it. I am getting this non-fatal error and would like to resolve it it...
5,222
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
45
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
185
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
74
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
114
