Omron comparison to siemens DB
Tommycai
Aug 2011
KY
120
so the CIO is for I/O
and the W0.00 is like Siemens M 0.0
What is comparable to Siemens DB?
I usually Map Siemens External I/O to a DB and then use that so If and Input or Output Changes I only change it in that one area is there something like that I can do in Omron?
I have not worked with Siemens for years so a bit rusty.
I think DBs are registers so would be DMs (data memories).
Some PLCs have retentive and non retentive registers - all Omron data memories are retentive.
Alternatively you can just use CIO in Omron if you do not want retentive registers - Omron memory map if very flexible and you can use CIO for everything - I cannot ever remember using W (work) bits at all - pointless to me when I can use CIO for virtually everything.
Be aware that H area is memory retentive also - both bits and words.
Siemens DB's from what I understand are like AB's Files or something in that Nature
When Creating a Siemens DB you can have that be addressed to another location.
What I usually do is make a Siemens DB #123, call it Inputs, and make another one called Siemens DB #321 call it Outputs.
I Then map the I/O address that are coming from the external cards that are connected to the plc (I/O cards). So if the address changes then all I have to do is change that one mapping location.
Hi guys! Can someone post how to use this function? Really having difficulties to use it. thanks. Regards, Brooks
3,631
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
67
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
199
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
78
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
135
