Omron CP1L communication via NAT
Stobe
Nov 2017
Timika
Dear other Members,
I am trying to make communication between multiple CP1L-EM plcs through NAT in router. I want to have same settings (IP etc) due to easier spare part handling in all 'slaves' and have router in front of each 'slave' and then make Node conversion table in 'master' i.e. link router WAN addresses to Node number in program in master. Master is trying to receive data from slaves.
I have been only able to make communication working with one plc but rest two I can't get communicating. CX programmer can communicate to each PLC at same time through routers. Is the case that having same node number setup in each 'slave' even though WAN-addresses have given node numbers in 'master' PLC?
The same communication works when Siemens is working as 'master' and receiving info from CP1L-EM PLCs. Does this maybe require using socket and sending read request?
Hello This is my first post on this forum so I will take this opportunity to say hello to everyone. I'm new to the PLC programming and...
2,052
Hi, Can you guys please help me to establish the communication between two OMRON CP1L-E series plcs using FINS communication protocol. May i know...
2,786
Hi everyone! I have an issue with some Omron CP1L-E PLC's. They're connected to get the info from production machines, but I've noticed that...
1,155
Hi! Omron CP1L. CX Programmer. How do I fix so that a CNTRX(548) remembers the count it had before a power failure? I need to know how many...
1,391
Hi! Newbie here... Cx-programmer CP1L PLC NB7 HMI I want to multiply something i by 1,5 in CX-Programmer to get a higher number to use in HMI...
2,235
