Omron CP1L CPU ethernet protocol ??
sahebanna
Nov 2009
Bangalore
16
Hi..
i want to know the Ethernet protocol (Ethernet IP or Ethernet TCP or Modbus TCP or any other) of omron CP1L CPU. CPU part number is
CP1L-EM40DR.
i searched in net, till i am not clear
Yankanchi.
Hello,
Omron uses the FINS protocol, TCP or UDP.
Cat. No. W421-E1-02
SYSMAC CS1W-ETN21/CJ1W-ETN21 Ethernet Units
OPERATION MANUAL
The built in Ethernet port in the CP1L-EM can only be used for TCP or UDP. As Mark has said it uses the Omron FINs protocol.
If you are requiring Modbus/TCP or Ethernet/IP you can get a comm's adaptor for the top of the PLC.
Modbus/TCP manual (can be master or slave)
http://echannel.omron247.com:8085/m.../CP1W-MODTCP61_SetupGuideManual_EN_201207.pdf
Ethernet/IP manual
http://echannel.omron247.com:8085/m...ile/CP1W-EIP61_SetupGuideManual_EN_201207.pdf
EIP EDS file attached
Hope this is useful.
Regards
Hi everyone! I have an issue with some Omron CP1L-E PLC's. They're connected to get the info from production machines, but I've noticed that...
1,179
Hi! Omron CP1L. CX Programmer. How do I fix so that a CNTRX(548) remembers the count it had before a power failure? I need to know how many...
1,410
Hi! Newbie here... Cx-programmer CP1L PLC NB7 HMI I want to multiply something i by 1,5 in CX-Programmer to get a higher number to use in HMI...
2,270
Hi all, I've been upgrading some machines recently which involves installing a 10" NB HMI, HUB and a CP1L-E to avail of the built-in ethernet...
1,718
Hi, is someone experiment connecting a Omron plc CP1L with a Siemens HMI TP1200?, i've installed the drivers in WinCC , plc options is just CS1 or...
1,923
