Omron CP1L to NT11 Screen Help
Critt
Apr 2006
Ontario
153
Hello All
I have an Omron CP1L Controller communicating with an Omron NT11 HMI screen.
My Problem is the HMI seems to be only displaying values in HEX?? (Even when the decimal is setup in the configuration)
I have tried both Host Link and NT link with the same problem.
Any help will be great!!
Most likely that the HMI can only display BCD values.
Has this PLC been converted from an earlier model?
You could try changing the values in the PLC to BCD (y)
Hi everyone! I have an issue with some Omron CP1L-E PLC's. They're connected to get the info from production machines, but I've noticed that...
1,158
Hi! Omron CP1L. CX Programmer. How do I fix so that a CNTRX(548) remembers the count it had before a power failure? I need to know how many...
1,395
Hi! Newbie here... Cx-programmer CP1L PLC NB7 HMI I want to multiply something i by 1,5 in CX-Programmer to get a higher number to use in HMI...
2,241
Hi all, I've been upgrading some machines recently which involves installing a 10" NB HMI, HUB and a CP1L-E to avail of the built-in ethernet...
1,705
Hi, is someone experiment connecting a Omron plc CP1L with a Siemens HMI TP1200?, i've installed the drivers in WinCC , plc options is just CS1 or...
1,914
