Omron CPM2A Questions
Clear Blue
Nov 2009
Portland, Oregon
Hello group,
I have an opportunity to acquire several Omron CPM2A units.
They will come with an Omron S8VS 06024 Power supply and some other hardware?
In my online searches it appears that I need special software called SYSWIN to be able to interface and program this unit.
This software does not appear to be downloadable from anywhere online. Including Omron's website(s) (that I have found)
From what I have read this software apparently needs a dongle to work.
So - is this the case?
Does Omron or an authorized dealer still provide the software?
Is it free or cost a fee? How much of a fee?
Can the software be obtained elsewhere?
Anything else I should know about these units?
Are they good, robust etc.?
Please advise with info that you have.
Thank you in advance.
Clear Blue
They are typical shoebox PLCs. Syswin is no longer available commercially. If you do a search here for Syswin you will find some references - I think one of them has a download link. Otherwise contact your Omron office and see if they will supply it to you free of charge.
CX-Programmer will also program the PLC but it is part of a suite of software that programs all Omron devices. If it is a home project it would probably be too expensive for you.
Personally I would buy the latest shoebox the CP1 but I designs and build systems for a living and use all the latest equipment and software. I only use CX-Programmer these days and have not used Syswin for many years now.
I find Omron PLCs to be very reliable and at least as rugged as just about anything on the market.
Hi all, My name is Firdaus. I am a teacher. And for the next semester I have to teach PLC to student. The problem is, I just move to this school...
1,999
Hi Folks. I have a problem with an Omron CPM2A-60CDT1-D High Speed Counter. It had been working well, the problem arose when a very minor program...
1,468
Hi Folks. I have a problem with an Omron CPM2A High Speed Counter. It had been working well, but the problem is that a program change was...
1,380
Omron's CPM2A has a compact flash card slot. Can an Omron program simply be copied to a compact flash card using a Card Reader or must it be...
1,524
Our company using OMRON sysmac CPM2A plc for small machine. presently we dont have the software to connect to PLC. Please anyone can send me the...
1,556
