Omron Cs1w-drm21
sundar_recr
May 2006
Coimbatore,Tamilnadu.
IN MY COMPANY WE ARE USING OMRON CS1W-DRM21V1 MODULE AS A MASTER UNIT.
THROUGH DEVICENET WE CONNECTED DRT2-ID16 & DRT2-OD16 INPUT & OUTPUT MODULE AS A SLAVE.
IN ONE INPUT MODULE (DRT2-ID16) E6CP-AG5C ABSOLUTE ENCODER SIGNAL DIRECTLY CONNECTED. BUT THERE IS NO HIGH SPEED COUNTER MODULE.
HOW TO GET THE ENCODER DATA(PLC PROGRAMMING) FROM THIS DIGITAL INPUT MODULE?
The modules that you are speaking, are DeviceNet Remote IO.
Have you configured these modules on the DeviceNet configurator without any problems?
Is the network working fine?
If you check the specs on these modules the max. freq. is around 300Hz. Is the input frequency lower?
MifPT
The E6CP is an absolute gray code encoder.
It is not a "pulse generator".
To read the encoder data, you should be able to monitor the channel that the DRT2-ID16 is mapped into.
You will need to write plc code to "decode" the gray code.
The question about the network working properly is also a valid question. You should be able to look at the NS and MS indicators on the modules. Both should be green and solid (not blinking).
Hope this will help.
:banghead: Anybody know of a link to the CS1W-DRM21 manual? Ive been looking on the omron site for the last half hour, and im about to throw...
6,155
Hi everybody, I can't transfer data from laptop to omron sysmac cj1m cpu11. I use cable "omron cs1w-cn118" and Uport 1150 (RS232),I sure software...
3,917
We want to purchase a high-speed data recording module CS1W-SPU01-V2 for CS-series PLC and still wondering what to buy the software. We definitely...
1,986
Hello, anyone have the pinout for the Omron cable cs1w-cn118? I am trying to see the different between CS1W-CN226 cable (programmer cable)...
13,799
