Omron cv500-cpu01-v1
jamber
Oct 2020
Laguna
Hi guys,
Is there someone using this type of PLC as of today?
I have no idea on how to connect and upload the program of this old type PLC. Unfortunately we have this type of PLC and we need to convert for the latest model but I need also to upload its program.
needed:
1. communication cable
2. wiring configuration of cable
3. etc.
Someone can help?
CVSS & SSS are the two programs, however, I believe the CVSS does not support later versions on some instructions (it will depend on the version number and if some instructions are programmed in the PLC.
Here is a link to a manual, this may help you out.
hi, Anybody knows how to program this unit?🤞🏻
3,612
Hi Guys............... RS232C/RS422 port of a Omron CVM1-CPU11-V1 PLC is not working. I need this RS232C port (for communication between PLC and...
7,187
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
151
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
64
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
104
