Omron CX-one Lite
shane_bac
May 2014
Derbyshire
23
Hi all, I have been asked to program a simple sequence using the CX-one Lite package. I have been using Siemens step 7 TIA for the last year and have found it to e quite different.
First off following the manual with the program example i do not have the option to edit the rack to add my expansion module to my CP1E 40 I/O?
Secondly ive noticed that al the memory allocations are some wht different, am I right in thinking that the work area is pretty much the same as the memory_bit in siemens?
Any help would be grateful please.
Heaps of options. The CP1L is fixed addressing - expansions just follow on. As far as memory goes W is a work area or you can just use CIO area that is not being used by real I/O. H is memory retentive, D is registers and they are retentive.
Thank you. Would i be right in thinking that i would use (W) for memory bits which are non retentive and (H) for memory bits which are retentive e.g a step in an automatic sequence that need to be remembered if power is lost? Would (D) then be used for storing such things amount of full cycles a machine has done for example?
Yes and no - I normally do not even bother with W but just use CIO. D area is normally used for calcs, setting up various cards, Modbus comms - heaps of things.
I find it easier as new user and a beginner to PLC programing, if it has the work area memory assigned for a particular purpose it seems sensible to use it?
I am looking for the best way of implementing the N/C input from the two hand start safety relay for the program. I have put the N/C logic in front of each of the output steps e.g when step 4 is complete and the safety relay is activated the output will be activated. The problem with this is that if i lose power to the N/C contact then it will think the safety relay has been activated?
This is protected by the fact it is wired to Category 4 with constant monitering but i still want the logic to be correct.
hi all, I'm trying to develop a GUI in V. basic 2008 to write values in memory adresses of an OMRON CPM1A-40 PLC. I'm using cx-programmer for...
5,986
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
68
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
201
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
78
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
135
