Omron CX Supervisor- Active X function
Shawn Cassidy
Mar 2004
Montreal
98
I am doing a project using CX Supervisor. I'm doing mostly data collection and monitoring of machines. I'm trying to add a marquee to inform plant operators when machines are in alarm and display the problem with the machine on the marquee. The marquee is made by EZ Automation and it is a 2 line, 3 color display. It has Ethernet and serial communications built-in. I can send ascii messages to the marquee serially from the plc, but would like to send via Ethernet from CX Supervisor. I've been told that I can use Active X to generate messages to send to the display, but haven't been able to find any examples as of yet. Right now I'm using the EZ Marquee software provided by EZ Automation to send messages manually. Basically it is an ascii string generator that turns text into a string that the marquee will understand. It then sends it to the IP address you want and displays that message until a new message is sent. Has anyone done this before? Does anyone have any ideas how to use the Activce X controls to perform a task like this? Any help would be very much appreciated.🤞🏻
Hello, Never done a project with cx-supervisor, but I would need to edit existing compiled project. Is it possible to get the (PLC) point data...
1,299
Hi What is the best solution to have a comunication between a PC (XP OS) with a HMI CX Supervisor and a PLC OMRON CQM1H? The distance between...
2,064
hi , i'm using CX supervisor and while assigning an input/output value to a tag its showing that DATA location is invalid for this type of...
3,034
Have just finished working with a intergrator to replace a Beckhoff CX 1000 unit with a Advantech Industrial Panel. Kept having connection...
9,385
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
180
