Omron frequency inverter and S7 project(Profibus) what can you say about it?
Valera
Jan 2004
Saransk town Russia
147
Hi!!
There is existing project Step 7 whith 20 frequency inverters Danfoss. Can I add to this project/real hardware 4 Omron frequency inverters? I think that if this inverters will be have .gsd file then I can install this file in the Hardware editor Step 7 then I will can add this frequency to the project then I must write program for control inverter (Step7). And I have questions: how can I know WORDS for read/write data to the Omron Frequency inverter through Profibus DP and (there is Danfoss inverter on the Profibus DP bus) will be all OK for Omron freq.inverter control (through Profibus DP by S7-3XX PLC)?
I'm sorry for my bad english.I can read very well no write.
Best regards
Hi Valera.
That is correct.
how can I know WORDS for read/write data to the Omron Frequency inverter through Profibus DP ...
You have to check the ORMRON manuals. Dont count on that the setup is similar to the Danfoss drives.
... will be all OK for Omron freq.inverter control (through Profibus DP by S7-3XX PLC)?
It ought to be OK. The whole idea with Profibus is that equipment from different vendors can exist and function together.
I'm playing around with the pulse output functions of Omron CP1L and I would like to monitor the output frequency in data trace. I do not see a...
6,496
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
174
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
64
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
108
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
258
