OMRON FZ2-350-10 help please
sheryl86_ann
Jul 2008
laguna
142
Hi there!I would like to ask if somebody can led me to a site / or send a copy of a detailed manual (just in case you have, please)of FZ2-350-10 controller (omron. We are using this for o-ring inspection.I cannot find in the internet the detailed meaning and purpose of its input/ output wirings. Like if the result is NG, what wire or signal will I need to use so that this will trigger contact to the PLC.I am a beginner in this controller. Does anyone encountered like this? Please help. I am using OMRON PLC.
Thank you.
PS: Thanks to mr. Gilbert(Gil47)
Sir gtsuport:
Greetings!
Thank you very much for leading me to this site. I find it hard to print this page before, I need to do it one by one procedure this the one I had is not in PDF format. Are u very particular with this product? I mean, can you help me know when to use the wiring connection and the meaning of its purpose? I can only read like it says that for measurement.. thats for all inputs or outputs.. but when to use or how to use the measurements?
Thank you very much!
Sincerely,
sheryl - Philippines
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
45
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
185
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
74
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
114
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
272
