Omron I/O units
yahmsn
May 2018
Karaj
We have CJ1W-OD232 and CJ1W-ID232 to our plc and I want use them in the program but I dont know the memory allocation of them.
Could any one help me or introduce me the manual?
Thank you so much for your helps
yahmsn,
Welcome to the forum.
Both of those modules will use two consecutive I/O channels.
If you look at the I/O Table in the Project workspace on the left side of the CX-Programmer screen, it will show you the starting I/O channel for the module.
I hope this will help.
yahmsn,
welcome to the forum.
Both of those modules will use two consecutive i/o channels.
If you look at the i/o table in the project workspace on the left side of the cx-programmer screen, it will show you the starting i/o channel for the module.
thank you
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
50
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
185
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
74
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
114
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
273
