Omron MC421
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Hello, I would like to slow down a servo motor. It is a Yaskawa Sigma 7 servo amp and motor controlled by an Omron MC421. I am not sure if it is better to do this through the Yaskawa parameters or the Omron parameters. I only want the one axis slowed down (it is a 3-axis machine). The MC421 is using G-code programming. It will move all 3 axes at G00, simultaneously and it's great for 2 of the motors however, the third axis moves way to fast. I wasn't sure if simply changing this, would work:
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
60
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
188
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
76
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
126
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
284
