Omron NA5 HMI screen issues with crashing
Killercal
Aug 2006
Ontario
150
Hello all, I'm new to the Sysmac Studio software and I'm having an issue with the HMI screens crashing.
I have a screen that shows the active alarms. I do this with the "User Alarm Viewer" tool and by adding Groups under the "User Alarms".
I have 42 different alarm groups and each one has its own tag that the expression looks at to trigger the alarms. I have made sure that I don't have any overlapping tags in any of the groups and the tag arrays are larger or equal to the size of the group associated with it. All the tags in the HMI global variables match the size of the ones in the PLC global variables.
The crashing issue only happens when I'm on the Alarm screen, but it doesn't happen right away, sometimes it takes 5 minutes and sometimes longer.
Has anyone seen this and does anyone know how fix it or even know what I should be looking for?
I have attached what the crash shows.
Hi all, I have to say first that I have no experience with Omron devices, but here's the challenge that I'm facing. I have an Omron CP1H...
1,708
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
155
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
64
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
104
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
257
