Omron NJ301 and CompactLogix 1769-L33ER EthernetIP Implicit Messaging
fremebondo
Jun 2014
Italy
Hi guys,
I am trying to share two tag sets (omron2ab and ab2omron) between the above mentioned cpu.
I tried installing the 1769-L33ER CPU eds in Omron Network Configurator but I am not able to configure its tags, and then to define connections.
No better luck in RS Logix 5000, as I am not able to find any NJ eds to install. Tried with EIP21 but not able to define tags here either.
Any one did something like that?
Please, do not redirect me to tutorials of similar device as probably I have already read it, but the procedure is not appliable to the CPUs I am working on.
Many thanks!!!
Since I discovered the Red Lion datastation plus, I have found data exchange between different PLCs extremely simple.
Messing around with direct comms between these 2 PLCs while technically possible will cost a lot of time with trial and error and pain. You may even shed a tear or two.
The Red Lion will do it simply for less than US$1000.
Thank you Sergei!!!
I was missing the 4 status bytes from AB to Omron, and your guide was very helpful!
Now it works like a charm, and it seems we saved around $1000 🍺
Good to know it works. I thought you would need and EDS in AB. I will hang on to that guide in case I need it.
I suppose I am a little pessimistic after once I wasted a week trying to get Omron Profinet card talking to Siemens PLC only to eventually give up and got the red lion working in half an hour.
Hi I am using Omron NJ301-1200 CPU unit and using CX-Programmer Software for PLC Programming. When i create a New Project it is asking to select...
3,077
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
145
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
63
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
102
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
256
